Old 05-27-2008, 12:37 PM   #6 (permalink)
NoCO2
Bicycle Junky
NoCO2's Avatar
Putsaround - '96 Camry LE
90 day: 32.74 mpg (US)
The Commuter - '07 1000SL
90 day: 617.28 mpg (US)
Zippy - '91 Civic DX
90 day: 33.29 mpg (US)
I will agree with the definitions there.
I personally would never inflate my tires past the limit posted on the tire. I always assume that the manufacturer has tested these tires to a point that the number on the outside stands for some point at which some of the tested tires began to fail after use. I actually go even beyond that and will adjust my tires based on my driving for the day. I have found that my tires will go up by a factor of 'x' based on what kind of driving I'm doing, more so for highway driving then around town driving, so I keep them at the max listed on the sidewall unless I'm going on the highway where the temperature will cause the 'x' factor of expansion to occur in which case I release pressure enough so that it stays within safe limits while they are heated up.
