Old 05-27-2008, 07:36 PM   #16 (permalink)
Ryland
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
If you just cut fuel going to the carburetor the carb still has fuel in the float bowl, enough to go maybe a quarter mile or more, then it will slowly lean out, at this point your engine is running really lean and this seems like a bad idea as an extremely lean burning engine tends to over heat the engine, this is why when honda started implementing this very idea in the mid 70's they put 4-5 solenoids on the carb, one on each supply to each jet, it added some complexity to the carb, but made the car use alot less gas.
