02-26-2012, 05:17 PM
#10 (permalink)
Cyborg ECU
Originally Posted by Ladogaboy
I want to add something to Post #8. What oil pan 4 was saying in regards to diesel turbos "loving their cylinders stuffed with air" would apply to at least some gas turbos. I was doing some more research on my car's tuning, and its AFR range is from 9-11:1 from factory. By eliminating back pressure in the exhaust, the AFR does improve. I'm not sure how much fuel efficiency can by gained by increasing from, say, a 10:1 AFR to a 12:1 AFR, but that seems to be a pretty common shift.
I added this point, and all of these:
About the only application where adding larger pipe and muffler or removing the muffler is going to help will be a turbo diesel.
Turbos like as little back pressure as possible and diesel engines love having their cylinders stuffed with air mass even at light load.
Elimination of back pressure has benefits in gas turbocharged engines as well, but top-end power is where this is primarily seen. In regards to fuel economy, I don't know of any proven effects either way.
Originally Posted by viio
