Old 02-28-2012, 12:47 PM   #17 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Okay, I realize I'm a diesel guy and I'm not super familiar with tuning gasoline engines, but something doesn't make sense to me.
The soichiometric air-fuel ratio for gasoline is 14.7:1. This means that if you combine 14.7 kg of air with 1 kg of fuel in a perfectly mixed mixture and burn, all the fuel and all the oxygen in the air will be consumed. Greater than 14.7:1 means there will be oxygen left over, lower than 14.7:1 means that there will be unburned fuel left over. 9 to 1 air fuel ratio is equivalent to 14.7 to 1.64. That means 64% extra fuel! Of the 1.64 kgs of fuel sent in only 1 kg has the possibility of burning--even in a perfectly mixed mixture. So a minimum of 40% of the fuel will go unburned.
Now, I realize that sometimes the AFR will go just a little under 14.7:1 under high power situations, because the mixing isn't perfect. I also realize that ethanol and some other fuels have stoich AFR's down close to 9:1, but I don't see how 9:1 with gasoline can be anything but bad.
What am I missing here?
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
