Old 03-05-2012, 10:09 AM   #10 (permalink)
skyking
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
[QUOTE=Ken Fry;291021]
Originally Posted by skyking View Post
A related technique, used with epoxy, is covering the layup with peel ply, which can be formed into a compound curve. This leaves a surface that permits secondary bonding without the need for sanding. But it also permits light sanding, in preparation for painting, without getting down to the glass. Sanding with 150 grit, then using a high fill primer and one sanding of that is usually enough prep for finish painting.
Bubbles might be a little easier to work out of peel ply. Both techniques can be useful for different conditions. (Peel ply replaces the fiberglass fabric weave surface with a much finer dacron weave, which is not glossy.)
Ken, I have learned that peel ply is Polyester Taffeta at the discount fabric store
I am buying some for $2.45 per yard in 48" width to do some testing.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
The Following User Says Thank You to skyking For This Useful Post:
turbothrush (03-05-2012)
