bisecting the beast
I'm an incurable aeroholic and always on call to take a Sawsall or cutting- torch to an otherwise,perfectly functionable automobile.Having said that,a project,with the scope as you propose it, would scare me off.The practicality and safety issues expressed by some of the members should temper your enthusiasm for such an ambitious path.If you're willing to invest all those cubic man-hours of labor,you should end up with something truly ahead of the curve.I'd consider building something from a kit or plans.There's some stuff out there which will stand the test of time that you could emulate,and the engineering and physics has already been figured for you.I applaud your premise,but I think there's a simpler path with potential for even greater reward.Check out EV World and maxmpg and see whats already out there.Ebay may have orphaned EV project cars ready for a new home.The more you look the more options will unfold.Make all your mistakes on paper,then when you feel you've made the best choice,jump in with all you've got!Best to ya.
