Old 05-29-2008, 12:08 PM   #171 (permalink)
jmonroe
silverciv - '01 Civic EX 2dr
90 day: 36.13 mpg (US)
I think I might wire up the LCD in parallel and try to cut out the SoftwareSerial completely if I can.
Actually, I might be able to test without the LCD. Once the ELM has established a connection with the ECU, it will send a signal ever second or two to keep the connection alive and the OBDTX light flashes. If I run the code without software serial or an LCD, I should be able to see that light flash and the ELM maintain a connection even though I can't view the data.
