Old 12-23-2007, 12:55 PM   #5 (permalink)
Daox
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Your 2nd assumption is correct. There is simply a bored hole in the aluminum block. The heater slides into the hole with some thermal grease around it. It is secured from sliding out by a little metal clip that hooks onto the block. I assume they went to this style when they went with aluminum blocks. I'm really glad I didn't have to mess around and knock out a freeze plug. Thats what I thought I was going to have to do.
