Old 05-29-2008, 01:43 PM   #22 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
CapriRacer -
Originally Posted by CapriRacer View Post
I'm starting a discussion thread here - and I'm hoping to move a discussion that got started when I introduced myself:
http://www.ecomodder.com/forum/showt...ires-2522.html
So hopefully this will be a bit more visible and a bit more "on topic".
First, let's define some terms:
Underinflation: Using less inflation pressure than is listed on the vehicle placard (assuming the placard tire size is being used.)
Overinflation: Using more inflation pressure than is listed on the vehicle placard (assuming the placard tire size is being used.)
Hyperinflation: Using more inflation pressure than the maximum listed on the tire sidewall.
Vehicle placard: The sticker on the vehicle that lists the original tire size and the proper inflation pressure for that size.
Agree?
Any other terms we need to define?
I would add :
Maxinflation: Inflating to the maximum listed on the tire sidewall.
I *deliberately* got LRR tires rated at 51 PSI so I could go "pressure to the max" and not worry about violating the sidewall max.
This is a site I reference to others because I think it has a *lot* of good info on tire technology :
The wheel and tyre Bible
http://www.carbibles.com/tyre_bible.html
CarloSW2
American Solar Energy Society
