Old 03-26-2012, 03:26 PM   #1 (permalink)
MetroMPG
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Speed vs. fuel economy: 2010 Jeep Patriot 2.4 CVT 2WD graph/chart
This weekend, I drove a friend's 2012 Jeep Patriot from Ontario to Nova Scotia, about 1800 km (~1100 miles). It's the 2.4L 4-cylinder engine, automatic CVT. 2-wheel drive.
It just so happened it was a calm early morning when I left, so since I was going to be driving through one of my two ideal (smooth & level) "test courses", I did a speed vs. fuel consumption test with the Jeep.
Note that these were not paired & averaged (E/W) runs. I just did one run at each speed (ie. went one direction, turned around and bumped up the speed for other direction. Rinse & repeat).
Where there's a datapoint missing for a speed, it's because of (a) interference from other traffic, or (b) I screwed up the ScanGauge reset.
Conditions:
9 degrees Celsius /
Wind: light, N/W (6 km/h / 4 mph) That was a direct cross-wind on this NE/SW road.
Results:
KM/H / MPH ... MPG (US) ... L/100 km ... MPG (Imperial)
50 / 31.1 ... 32.3 ... 7.3 ... 38.8
70 / 43.5 ... 31.5 ... 7.5 ... 37.8
80 / 49.7 ... 29.3 ... 8.0 ... 35.2
90 / 55.9 ... 28.3 ... 8.3 ... 34.0
100 / 62.1 ... 26.2 ... 9.0 ... 31.5
120 / 74.6 ... 22.9 ... 10.3 ... 27.5
130 / 80.8 ... 19.2 ... 12.3 ... 23.1
EPA rating for this drivetrain is: 21 / 25 / 23 MPG (US) city / hwy / combined: Gas Mileage of 2010 Jeep Patriot
On this drive, I also learned some interesting things about the CVT (continuously variable transmission) - specifically, how to "short shift" it in manual mode. See: http://ecomodder.com/forum/showthrea...rly-21149.html
The Following 2 Users Say Thank You to MetroMPG For This Useful Post:
aerohead (07-31-2015), Xist (07-21-2015)
