Old 05-30-2008, 02:32 PM   #21 (permalink)
TheDon
TheDon's Avatar
Pepper - '87 300D
90 day: 30.42 mpg (US)
Originally Posted by FastPlastic View Post
I just used a piece from a broken picture frame. So it is pretty thin, which makes it easy to curve around bends. If you want to be lazy you could just pick up a picture frame from Wal-mart $10. Otherwise if you have a local hobby store (Hobby Lobby around here). I've seen the same size sheet for about $6. Another reason I choose to do it this way, be it harder because you have 5-7 slots to fill. I can always pop one or two out if I start having heat problems.
cool, I found a bunch of transparency sheets so I'll play with those
