I just setup a governing block on the cam that pulls the cruise cable. Essentially, it will pull the throttle setting (in my case, a ~12% throttle limit) up to the set speed, and then on hills, modulate the throttle for the set speed as usual. If the limit is hit on a hill or in strong winds, the load-up/slow-down occurs. It overshoots the setpoint a bit on downhills, but not much. It's still good if you need to focus on other things, or are too fatigued to hypermile.
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
 _
 _
