Old 04-05-2012, 05:40 PM   #1 (permalink)
GoGreenAuto
GoGreenAuto's Avatar
Silver Bullet - '01 Honda Insight Hybrid
90 day: 55.32 mpg (US)
Got a few MPG from new wheels and tires and lowering springs
Car is a 2003 Honda Civic Hybrid with 237k. I was getting 48.4 all day long with the factory wheels and some junk tires. Put a set of Konig Helium Ultralight rims with Zeix 512s on there. 4lbs lighter per wheel! Running 42psi front and rear. That took her to 48.8.
Also lowered it 1.3" with a set of Skunk 2 springs for another few points, currently getting 49.2mpg. And that's all without the IMA system working yet!!
Goals; get the IMA working, maybe install an MIMA, and try some LRR tires on the factory rims. Might try making a belly pan for it too, there's definately some drag on the underside where the back of the K frame is and a HUGE pocket where the muffler is.
