Old 05-31-2008, 10:12 AM   #3 (permalink)
JohnnyGrey
Pushrod - '02 Cavalier
You can't correct the AFR to compensate for dead cylinders. The mixture will ALWAYS read lean no matter how rich the other two are running. You have to run in open loop mode while the cylinders are disabled.
