Old 04-13-2012, 02:55 AM   #9 (permalink)
RiderofBikes
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
Originally Posted by FXSTi View Post
Did you have to curve them out or is it a flat panel? I have the SES with the 16" wheels and wider tires, form holding a straight edge across the body it looks like I would need a curve.
As MetroMPG said, get a gauge.
Anyway, You ROCK!!!
Yes a curve is required I wanted to extend them down more to flow with the bottom body line. Impossible from the material size I was able to get(couldnt find a nice 4x8 sheet of coroplast) had to rotate the pieces I had and line them up corner to corner to fill that span and cut off what couldnt be used. I used some metal support stripping behind it and sorta stapled it through so it wouldnt flop around and rub on the tire. but the thing is solid! and doesnt deflct at speed.
I'll see about taking a picture from the inside of the panel
No smart phone here...
I'll be getting a gauge within the next couple months if funds are willing.
I'll be sure and register with the site you mentioned!!
Of course, I'd love to see what you were able to do with yours!
