I think I'll go ahead and take off the cross bars on the roof rack. I'm planning on leaving the tracks because I don't want the roof to leak. Had problems with the last Jeep ceiling so don't want to take any chances.
As long as you put the bolts back in, it shouldn't be a leaking problem. Also, using silicone sealant, you probably won't be able to remove the torx screws after 20+ years unless you ruin your roof. Someone siliconed my valve cover onto the block and it was a B**** to remove (had to do the dreaded prying *shudders*).
Here's a link to the stuff I've done so far to my jeep. I'm gonna add more things on there like my block heater install. You can get idea's from there.
DPoV's Jeepin' build thread
