04-17-2012, 11:25 AM
Originally Posted by JanvdW
Hi,
I am trying to find EPA ratings for my vehicle, but it is not listed on the US site.
(I think it is not imported to the US)
It is a Land Rover Defender 110, 1998 model.
300Tdi engine (2.5 liter 4 cylinder)
Anyone got an idea where to find the EPA?
thanks
I'm sure this is of little use but MSN autos which is a good specifications resource lists the 1993 Defender 110 V8 as 10 city/12 highway MPG (US).
Wait...
I got you covered...
Data for LAND-ROVER DEFENDER 110 COUNTY 300Tdi, manufactured or sold in 1998, version for Europe with 5-door wagon body type, 4x4 full-time (all-wheel drive permanent, manually locked centre differential), LT230T transfer case 3.32/1.41 and manual 5-speed gearbox. Basic Automobile-Catalog the complete Catalog of Cars specs and characteristics: diesel engine of 2495 cm3 / 152.3 cui displacement with advertised power 83 kW / 111 hp / 113 PS ( ECE ) / 4000 and 265 Nm / 195 lb-ft / 1800 of torque. Dimensions: this model outside length is 4599 mm / 181.1 in, it’s 1790 mm / 70.5 in wide and has wheelbase of 2794 mm / 110 in. The officially claimed value of a drag coefficient Cd = 0.65 . Standard wheels were fitted with tires size 205 SR 16. Reference vehicle weights are: official base curb weight 1979 kg / 4363 lbs, gross weight GVWR 2950 kg / 6504 lbs. How fast is that car ? Performance: top speed 129 km/h (80 mph) (declared by factory); accelerations 0- 60 mph 17.4 s, 0- 100 km/h 18.1 s (declared by factory), 1/4 mile drag time (402 m) 20.6 s (a-c simulation). Fuel consumption and mileage: official: 11.4 l/100km / 24.9 mpg (imp.) / 20.8 mpg (U.S.) / 8.8 km/l 10.1 l/100km / 28 mpg (imp.) / 23.3 mpg (U.S.) / 9.9 km/l , average estimated by a-c: 11 l/100km / 25.9 mpg (imp.) / 21.6 mpg (U.S.) / 9.2 km/l, average estimated combined driving range of this car is 734 km / 455 miles. To view table with this car complete performance data and technical specifications (including final drive and gear ratios, powertrain description, inside and outside dimensions, acceleration graphs etc.) and more photos, or to compare up to 5 cars side-by-side - click one of the the buttons below:
1998 Land-Rover Defender 110 Station Wagon specs, performance, photo & data
Civic Build Thread
Your grammar is appreciated.
3.788 Civic CX final drive, air dam, 1st gen HCH 14" wheels and Michelin Defender 175/65R14 LRR tires
