Old 04-19-2012, 05:27 AM   #29 (permalink)
kevman
Originally Posted by t vago View Post
What difference does it make? You completely missed the point.
Engineers work with reality.
your posts are quite informative & you clearly Know your thermo, i get your arguement on latent heats required just to arrive at the point where water turns to steam.
but then again, your only considering the heat energy available/escaping with the exhaust gasses.
let me ask you this, theoretically speaking, an ideal engine will have no/minimum heat transfer to outside the working medium (pison/valves/cylinder ect) correct? that is why ceramic coated pistons/liners/sleeves ect are benificial as i understand it. which means more heat trapped inside to do work.
The Following 3 Users Say Thank You to kevman For This Useful Post:
ConnClark (04-19-2012), jdchmiel (02-23-2014), t vago (04-19-2012)
