Old 06-01-2008, 06:31 PM   #2 (permalink)
Coyote X
nut
Coyote X's Avatar
Metro XFi - '93 Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 DR650SE
90 day: 55.26 mpg (US)
Moonbeam - '94 Astro Conversion
90 day: 22.31 mpg (US)
Send a message via ICQ to Coyote X Send a message via AIM to Coyote X Send a message via MSN to Coyote X Send a message via Yahoo to Coyote X Send a message via Skype™ to Coyote X
That one has the vacuum advance on the distributor I think so to check timing you need to unhook those lines and plug them so the car will still idle.
If you didn't unhook them then 12 degrees is probably close. But I would still set it to around 8 degrees with the vac disconnected then when you plug it back in the timing will prob jump to around 15-18. I don't know of anyone that gets knock when they set the base timing to 8-10 but depending on driving style and stuff it is possible it will knock.
My Convertible Metro XFI Plug in Hybrid Project build log
