Old 06-01-2008, 09:08 PM   #4 (permalink)
Daox
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Do you have a scangauge? If so, set it to monitor closed/open loop mode. You should be accelerating as hard as you can without bumping it into open loop mode. In open loop you will be running rich air/fuel ratios and loosing the benefit of P&G.
