Old 06-02-2008, 06:51 AM   #41 (permalink)
Chris D.
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
Originally Posted by digitaldissent View Post
I have confirmed the steels are 15lbs and the factory alloys are 17lbs, tirerack says my tires are 18.
2mpg that's awesome, I knew it. Thanks ChrisD for the info
who's got a couple of grand for me?
No problem, but tirerack states your tire in your size is 17lbs..
look for "tires" then cross refference the size..
http://www.tirerack.com/tires/Spec.j...%3D86TR5RE92V2
Couple of grand?!? what do you have in mind for wheels?
15lbs for the steelies is pretty dam good
moon them and call it done
Originally Posted by Xringer View Post
I'll bet if you drove 25 mph in your Tacoma and measured the MPG and then
bolted 4'x8' sheet of plywood vertically on your tailgate, you would see a big
drop in your 25 mph FE.
I believe that cd is important at low speeds too. (Just ask anyone who races bicycles).
If the moons help the cd at 120+mph and didn't help some at 55 mph, I would be very surprised.
It's not like they are active device like a spoiler or VG, to my eye, they are pretty passive.
Kinda like rolling up your windows when you drive over 30.. It helps.
Your vertical 4x8 plywood tailgate setup is hardly compairable to hubcaps..
If the moons made any improvment, I'm sure EVERYONE on here would be running them.. I've read lots of a-b-a results and nothing showed any results...
my windows down vs up at 55mph doing a-b-a-b showed no signifigant change in FE on my truck utilizing my SGII and using the same distance stretch of highway..
I think my window visors have something to do with that, not sure..
thats another a-b-a test onto itself..
