Old 06-02-2008, 01:10 PM   #44 (permalink)
Xringer
Old Retired R&D Dude
Transporter - '09 Escape XLS
Originally Posted by i_am_socket View Post
I would think that the difference of hub cap design would depend on the vehicle in question. Has anybody seen tuft testing done for stock vs disc on a particular vehicle? Has anybody seen windtunnel tests at highway speeds for the same?
I'm not sure what the yarn would look like on a moon disc. But my guess is,
it would lay down in a spiral and maybe outwards towards the tips.
Depending on the yarn's weight or if a circular laminar air layer would exist on the surface of the disc.?.
Maybe do it small scale with a drill and sanding disk? Or glue a 14" coroplas disk on top of the sanding disk?
Somewhere, I've seen spinning disks where paint (in the center) flowed out to the edges, but I can't recall what the results looked like!
Would the wheels need to be spinning while the car was in a wind tunnel??
I think some wheels are designed to allow air to flow over disk brakes, for cooling. Maybe even force the air around the discs. With spokes acting like fan blades.
I wonder what mine are doing with the air?
Does centrifugal force (in the middle inside) fling air towards the outside of the rim? Where it exits out those 8 holes? Where it will have a dirtying effect on the air flow passing by the car?
I'm just trying to imagine what the turbulence and drag would be like, if I cut a round 2" hole in the vertical stabilizer on a model RC glider??
I'm almost positive it would have a very detrimental effect on airspeed, and the amount of control provided by the rudder..
I've seen pictures of those little Honda hub holes being taped over.. I'll bet there is some small positive affect.
Now I'm wondering if Zig-Zag tape just forward of the wheel wells would do anything for the cd.?.
Cheers,
Rich
Cheers,
Rich
