Old 06-02-2008, 12:27 PM   #1 (permalink)
MetroMPG
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Experiment: coast down distances (rolling resistance) @ various tire pressures
The purpose of the test was to get an idea of the difference in coasting distances in my '98 Metro/Firefly over a range of tire pressures, 20-60 psi.
EDIT Jan 23/09: Posted a summary of this thread at: http://metrompg.com/posts/tire-press...resistance.htm
Tire tested: 155/80/R13 Goodyear Invictas, rated 44 PSI max sidewall.
EDIT - Also tested Oct 13, 2011...
Bridgestone RE92 tires, multiple runs at pressures from 20-70 PSI. See this post: http://ecomodder.com/forum/showthrea...tml#post265379
Placard info: vehicle placard recommends 32 PSI front/rear @ max load.
Pressure Gauge: readings were taken with an Accutire digital gauge, 5-99 PSI rated, with a manufacturer accuracy claim of +/- 1% + 0.5
Weather: 19C / 66F, 10 km/h SSW wind (roadway ran SW/NE)
Methodology:
  • tires were pumped up to 60 PSI, drove to test route (< 5km), pressure adjusted
  • car was driven up a small hill (approx. 6 ft. elevation, 8:1 slope), turned around and stopped at a marked point
  • engine off, transmission in neutral, brakes were released
  • car rolled down short hill onto a flat run-out road
  • where the car stopped, the road was marked
  • pressure was adjusted (dropped 5 PSI)
  • rinse & repeat
  • NOTE: only one run per PSI
I used a bicycle wheel to measure the rolling distances - counted revolutions from the starting point, then converted circumference to total feet.
Ideally, I would have simply measured the coastdown distance from a constant speed at the same point on a level road, but my cruise control isn't working, and I didn't want to deal with the possibility of driver error (varying speeds). Even more ideally, I should have done multiple runs per pressure level.
Since the car accelerates from rest and coasts to a stop, the differences in pressure are amplified compared to a simple coastdown test.
Raw results for PSI/feet travelled
20 / 479.3
25 / 524.8
30 / 621.0
35 / 621.0
40 / 639.6
45 / 687.5
50 / 702.0
55 / 699.3
60 / 702.0
The Following 20 Users Say Thank You to MetroMPG For This Useful Post:
alexibu (04-08-2013), AndrzejM (04-01-2013), California98Civic (05-20-2013), Cd (10-13-2011), Daox (09-25-2014), drees (01-03-2012), fcporto (04-04-2013), Galvatron1 (01-12-2020), justjohn (05-03-2011), kurzer (01-02-2012), malibuguy (07-02-2019), MARTINSR (08-03-2010), mikeyjd (03-31-2013), RedDevil (04-04-2013), renault_megane_dci (04-07-2013), Sykomor (10-15-2011), UltArc (05-19-2013), user removed (04-01-2013), wyatt (04-05-2013), Xusn96 (09-25-2014)
