Old 06-02-2008, 03:37 PM   #1 (permalink)
trikkonceptz
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '010 Insight EX
90 day: 51.5 mpg (US)
Hybrid Electric Scion xB
Below are pictures of my show car, a 2004 Scion xB. It has been shown in this condition for 2 years earning every accolade I could possibly want, yet it has never netted me any gains other than friends and connections. Well dew to the economy and the price of gas I have pulled it off the show circuit for the rest of the year because it costs me way to much to travel with it. So I decided to put it down and begin fixing all the problems it has and basically redo it for the next show season.
Well I wanted to take this to the next level and take advantage of the down time and convert my B to a hybrid extended range electric car.
Here are my plans and I want your help in order to make this as efficient as possible with both as little down time as possible and at the least amount of money as reasonably possibly.
-Obtain the rear end assembly of the Japanese bB, which is AWD
-My interior is already gutted so I will simply build around the new components
-Use 2 motors to achieve a hwy speed of 70mph with a range of 300 miles or more based on the set up
-Tap my current sponsors for help. Like Tsunami, which sponsored my vehicle last year and provided my with all wiring plus two dry cell batteries which are half the size of a compact car battery but have as much CCA as a marine cell.
-Now here is the biggie; Transverse mount my gas engine, which means disengaging it from the tranny and using the engine to soley power the vehicle accessories like, a/c, engine alternator, PS, etc ...
-I would then build a shaft off the crank in the rear with a gear drive or pulley system that would power multiple high output alternators. How many I will have to calculate, but I can easily use multiple 240 amp alternators to achieve the charging ratio I need to maintain long distance driving.
-The vehicle already has an air suspension capable of handling the weight, which I can adjust to achieve max mpg for under car drag etc ...
-I am going to have another sponsor of mine, Dakota Digital, expand my current digital gauge set up in order to accomodate any gauge needs that may arise during the build.
This is the simple planning stage, so what I need from you guys is opinions on what type of electric motors I should use, etc ... and even if I should begin to incorporate solar paneling in my roof, which is completely flat. I figure if done right, which I capable of doing, I will have one of the first converted custom electric cars, plus a blueprint on how to retro fit gas powered vehicles. Hell if I am going to dump money into a show car, better have it work for me right? Oh yeah, that means I have to lose the Keg set up, which weighed heavy on this decision ... LOL
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
