If you're trying to actually measure/calculate CD or CDA, it's important.
But if all you want to do is determine if a mod is effective or not, having a flat road or access to altimeter info isn't critical - the relative differences in the coasting times will do.
I realize you're after hard data - just pointing it out for others who may only be going after improvements.
