Old 05-08-2012, 10:37 AM   #9 (permalink)
Josh8loop
Definately a Modder!
The wear and tear on the clutch is one thing I would be concerned about-those are fairly expensive and time consuming to repair. Now if you could fit an alternator/starter combo that would allow you to use it to start the vehicle instead of the bump start method. In any case what you have done is pretty neat, and since I have a VW Jetta TDI with the ALH motor, and similar IP I may at some point experiment with a similar mod.
2002 VW Jetta TDI 5-speed(completed 01M-5-speed swap at 155K miles) 45 MPG City with the 01M, 5-speed 60+ MPG City. Nokian Entyre Low RR Tires. Experimenting with the "Hybrid" 205 Deg F T-stat:
http://forums.tdiclub.com/showthread...=306799&page=4
