Old 06-02-2008, 05:54 PM   #10 (permalink)
ttoyoda
ttoyoda's Avatar
"Not really. Very good info would have been multiple runs at each pressure level to ensure I was getting accurate readings. "
You did do well, and deserve the credit. Very-very good info would be to either measure the temperature of the tire before and after each run, OR take an air tank with you and do the test again, but INCREASE the air pressure after each run.
You might consider checking the tire pressure before you begin the run, and right after you finish, to see if there is a measureable difference.
