The photos edbso provided were pretty cool, now here is a question. On the trailing edge of the wing the air started to break up again, so what if you used another strip measured and placed behind in the same lines, do you think the air would continue to follow that pattern or will it get disturbed again and negate the results. I ask because on a roof line you may have to use multiple rows of the zig zag tape to cover the entire surface area ..
Curious I guess, learning as I read along .. LOL
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
