Old 06-03-2008, 01:57 AM   #5 (permalink)
Ryland
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
Make sure that the hose you are insulating isn't part of the high pressure side or you may be holding heat in, instead of holding cold in, this would put a higher load on your A/C, if the A/C system was designed correctly this should already be the case so it shouldn't matter that they are not insulated.
