Old 06-03-2008, 01:32 PM   #3 (permalink)
Daox
Moderator
Daox's Paseo - '97 Paseo
90 day: 47.03 mpg (US)
Daox's Prius - '04 Prius
90 day: 46.53 mpg (US)
That is just his 5th gear set. The final drive ratio is the gear reduction that takes place at the differential. So, you'd have to swap in a new differential into the xA. Also, lower RPMs don't directly translate to better FE. It is all dependant on the engine design.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
- Efficient living and green home improvement
