Old 06-03-2008, 04:57 PM   #21 (permalink)
aerohead
airdam
Originally Posted by Bror Jace View Post
c0da, looks good. I have the same car (2006 LX) and have been wondering where I could start with aero mods as most of my driving is on limited-access highways and I could probably see a benefit.
My big concern is making things that don't make my late-model car (with less than 20K miles) look like a home-made P.O.S. I applaud guys with 10 year old cars that aren't afraid to bolt on skirts they cut with a pair of scissors, etc ... but I just can't do that to my new baby Civic.
If you make a piece to block off the bottom, I'd make several of the same ones and consider some openings in the middle to let some air through. Maybe make one with small openings totaling 25 square inches ... another 50 square inches, etc ... Making the template (properly) is probably going to be the largest chunk of your time ... multiple copies should be light work.
On most Hondas I've owned, the temp gauge is VERY stable and predictable. Any changes which adversely affect the cooling should be easily noticeable as long as you monitor the temp gauge.
I'm waiting for some innovative company to come out with an aero kit for these cars ... solid front wheel covers, rear wheel well skirts and a more efficient front splitter that bolts on underneath the front fender cover.
I made a MS Paint image of what I'm thinking of:
I like your MS Paint image.I did want to share with you that Bondo had lowered the airdam on his F-150 and lost a mile per gallon.When he re-sized it,even with the bottom of the undercarriage,the mileage came back.
