Old 06-08-2012, 08:56 AM   #203 (permalink)
H2 02
happy - '00 skoda 1.3mpi estate
"On the surface, the difference seems negligible. Yet, when you consider that the carbureted engine is tunable in a home garage with some simple jetting changes, it is possible to get a little more power out of that bike, which is not the case with the fuel injected engine."
This is wrong.. An EFI system can be adjusted via a laptop/notepad/tablet on the fly, or run closed loop against a preset lambda setting..
