Great injector reference source MilesPerTank. So far the Honda owners that are doing the Opengauge project are myself, AndrewJ, and you.
As far as getting the INJ/VSS signal source I'm still working on that. AndrewJ has said that going directly to the Injector itself has worked. He and I both tried tapping into the ECU connector wire but we didn't have luck with that. I'm going to follow AndrewJ's method as well.
I still haven't worked out the VSS yet. Right now I'm hooked up with the ECU wire but I don't know if its worked correctly since my Injector signal doesn't work yet. AndrewJ seems to have it working with the ECU wire. He and I both posted pretty good ECU pinouts on this thread if you need that as a reference.
As far as the C8 reference that's beyond my knowledge. But I have the USB and serial freeduino's from NKC and they have both worked fine.
