It's just one more way to keep the engine running at the best BSFC. You can "pulse" at that optimal rpm/throttle position, without changing speed. You get the same benefits, but without the air drag of the higher peak speed, or the crazy speed variations. Instead of building kinetic energy, you're building potential energy.
Seat-of-the-pants testing I've done shows this to be the better choice, for my car, in my area with the hills we have. My best highway run - 75mpg for 150 miles - was using this technique. Pulse from the bottom at ~45mph to just before the peak at ~60mph, glide up and over and down.
It seems to work better for manual than for automatic, though. I think DWL is better on hills for automatic.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
