Old 06-04-2008, 05:19 PM   #2 (permalink)
ebacherville
Veggiedynamics
Extreme CRX-HF - '87 CRX custom areo
90 day: 50.8 mpg (US)
to add cruise to a 5 speed all thats really diffrent is a secondary cut out switch on the clutch.. However ofter cruise isn't the most effective for getting best MPG.. however keep your foot from getting tired..
I know Jc Whitmey and other autoparts places like that have aftermarkey cruise setups.. usually they consist and a wheel speed sensor and a actuator that hoot to the throttle and then wiring and switchs and the control module and switches you turn it on and off from..
However if your adventurous enough you could do the old school "cruise control" .. like bajoos did on his areocivic.. the hand operated "throttle stop" when put in place it just holds the throttle for you in one position.
