Old 06-21-2012, 12:45 PM   #4 (permalink)
ksa8907
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
For less stress on components you would want to switch the ground, electrical current actually "flows" from negative to positive.
But since the ecm is probably on a relay that switches ground, you should be ok. Be sure to check the underhood pdc for relays.
