WHOA !!! If I understand you guys correctly, you are saying that by having the key on, if I slide the car back into drive the car will start up again? Is that Bump start?
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
