Originally Posted by trikkonceptz
WHOA !!! If I understand you guys correctly, you are saying that by having the key on, if I slide the car back into drive the car will start up again? Is that Bump start?
That probably won't do it. Don't know about your car, but the saturn had actual solenoids to select the gears when it was auto, and of course a "solenoid" to lock up the torque converter, so with a couple switches you coud select a gear and force the engine to turn over regardless of speed (bump start), the unknown is if it will actually handle operating in that mode for very long
