Old 06-04-2008, 10:10 PM   #7 (permalink)
JohnnyGrey
Pushrod - '02 Chevrolet Cavalier
Mine goes off with the parking brake engaged, so I did a "Redneck Fix" and grounded the parking brake wire so the DRL's are off but I will never know if my brakes are gone
This trick works only on 20th century Cavaliers. Newer ones will switch the DRLs back on if you exceed 5mph.
You need a switch that has 3 pins per pole.
