Thread: CdA list
Old 07-05-2012, 05:26 PM   #108 (permalink)
Sven7
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Originally Posted by Ken Fry View Post
If two manufacturers happened to make exactly the same car, but one uses mirrors in its frontal area, and the other does not, then the Cd values will be different.
Just a small correction to avoid confusion. Although mirrors can raise a car's drag coefficient (Cd), simply omitting them from the frontal area number will not change this measure. Changing frontal area will, however, affect CdA, which is the drag coefficient multiplied by the frontal area.
Removing the mirrors from the car will change CdA and may change Cd, depending on how aerodynamic the mirrors are.
That is all!
The Following User Says Thank You to Sven7 For This Useful Post:
aerohead (12-09-2021)
