Thanks for the input. I've read a couple other threads around here dealing with air dams and arrived at the conclusion, as you suggested, that it may be best to trim the air dam so its not so low. I'll also probably do a partial belly pan back to the point of the inside of the usual front bumper, if that makes sense.
