CRX HF reverse trike project
Me and a friend of mine just started a reverse trike project. The front will be a 88 Crx HF Stock at this time
First I removed all inside parts seats panels exc. Then gas tank taillights suspension and hatch. Doors So allot of weight will use the windshield and all up front and the floor for structure with some type of modified front skin bumper. He built the part of the cage today
just four points I bought a 10 point cage from Jegs. After the cage we need is dome we can mount a modified honda magma 700 rear frame and tire with some form of air shocks. I also will be using the same taillights and wiring and also the side rear glass.
My plan is to remove the center taillight insert with the logo Crx in it and chop the metal out and bring in the quarters skins and weld them up together This should give me a good boat tail shape to start and look kind of neat. So the tail will be three foot wide with the rear glass for good visibility and a plexiglas type hatch to fill in what is left of the hatch area. That is about all that is done at this time will update This is going to be a low cost easy build car.
More info to come Bryan
