Thread: VX lean burn
Old 06-05-2008, 03:06 PM   #7 (permalink)
TomO
That VX guy!
TomO's Avatar
Thrifty McGassaver - '94 Civc VX
90 day: 41.98 mpg (US)
2010 Elantra - '010 Elantra GLS
90 day: 27.23 mpg (US)
The Tank - '06 Touring DE
90 day: 66.87 mpg (US)
Send a message via AIM to TomO Send a message via Yahoo to TomO Send a message via Skype™ to TomO
Originally Posted by Nden View Post
Muchos Gracias TomO! So when I re-install a Z1 motor/egr/harness/ with this P07-ao1 ecu, do I need to do anything else? Thanks again and greatly appreciated.
AS long as the harness that was in there was wired up for the 5 wire, you'll be good to go.
Is my CA 5wire oxygen sensor the reason I'm getting a 48 CEL code with the 49-state lean burn ecu ??
Did you have to do any rewiring when you had the other motor in the car? I'd double check the wires for the O2 heater first at the ECU and the harness plug in the engine bay.
CivicVX.com<--- is down for now... PM me if you would like to help resurrect it.
