Old 06-05-2008, 05:14 PM   #213 (permalink)
cmags
cmags's Avatar
Scoob - '05 Impreza Outback Sport SE
90 day: 25.28 mpg (US)
Originally Posted by Njay View Post
MAP (air mass flow sensor, right?) sensors usually output a small voltage... the voltage range is probably different from car model to car model, but that only is easy to deal with. I don't know what other different sensor outputs are there.
MAP stands for Manifold Absolute Pressure - it's a different way of calculating the air intake than MAF, which is Mass Air Flow. MAF basically uses a heated element and allows the intake air to cool it off. I think the voltage that is read off the sensor is the voltage required to keep the element at a certain temp, but I'll have to look that up to be sure. MAP, on the other hand, is more complicated I believe, I'll get back to you on that one.
