Old 06-06-2008, 12:38 AM   #43 (permalink)
diesel_john
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
Ended up buying a new head, from TOP LINE the reman. cores are drying up for the VW diesels. If you got a worn out VW diesel that's a good core, the engine is worth $250. 5 speed manuals worth $'s too.
Now back to cylinder decomissioning project.
I think i'll go even fire and not worry about the balance.
Fuel flow will be easier to verify, because i'll measure the fuel from the two unused cylinders and return it to the tank. This will be exactly the same as the amount of fuel that i am using.
