If its not hooked to a VSS/INJ (IE sitting on my bench) is the tank.gallons() supposed to increment like a counter?
I've hooked it up in my car and I must have wired something up wrong.
I tapped the VSS properly I believe. As for the injecter, I tapped the brown lead of the farthest right injector ( standing in front of the car facing the engine).
Update
Ok fixed it. I tapped the VSS at the ECU. My MPH are half what they should be. I think i was using 8000 as the constant.
Reason: problems
