Old 08-12-2012, 09:44 PM   #64 (permalink)
3-Wheeler
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Originally Posted by jimepting View Post
I used coroplast in the center and aluminum panels at the front and back. I think that might be more rugged. I also used a lot of the automotive grade plastic "pop" fastners, which cannot rust. I'm thinking of removing the few bolts I used and coating them with anti-seeze grease.
The aluminum cannot be shaped into complex shapes, and that is a slight negative, but this can be compensated by using multiple panels. Not as smooth as 3-wheeler, but looking at production panels like the Audi A8, I think it is probably adequate.
Actually Jim, I am using Anti-Sieze compound on all metal fasteners as well. I found out about this from the body shop that did the repairs on the car.
Will report back on how well it works after another winter.
Jim.
The Following 2 Users Say Thank You to 3-Wheeler For This Useful Post:
HHOTDI (01-13-2013), mikeyjd (06-09-2013)
