Old 06-06-2008, 11:38 PM   #110 (permalink)
Red
Red's Avatar
Fish - '02 Sebring LXi
Send a message via MSN to Red Send a message via Yahoo to Red
The Suzukiclone transmissions also have weak 2nd gear synchros. My first one ground going up & down through 2nd. When I switched from 70w90 gear oil to a much lighter oil (approx 5w30 weight) the crunchiness lessened dramatically. Not perfect, but good.
Thats the weird thing about it, it only grinds going from 3rd->2nd. 1st->2nd no matter the RPM is a clean shift. Right now I'm running Redline MTL in it which is I think is a 70w-80 lube. Poking around HT and here shows that GM Syncromesh Friction Modified seems to help revive or give the syncros enough grip to work again.
