Old 06-07-2008, 11:45 AM   #1 (permalink)
Cd
Ultimate Fail
Cd's Avatar
CV boots-need mechanical advice please
I'm not sure what these things are called, but from what I understand they are CV joint related.
Can someone in the know explain what these rubber boots are and what they do ?
Do they just seal in the grease, or do they perform some other vital function ?
If they do indeed just seal in the grease, can I just clamp them down using a hose clamp, or must I get them replaced ?
What could happen if I continue driving the car with these things split like this ? Will I lose control of the car and crash, or have my wheels fall off ?
I'd like to just be able to clamp them back into place and forget about them, but I'd rather be safe than cheap.
Thanks for any advice !
(This is on a '93 Civic by the way.)
"You don't fail until you give up. You learn, and move on." - Christ
" Hypermiling is not going slow, it's driving with more intelligence." - UFO
