Old 08-29-2012, 01:25 PM   #28 (permalink)
320touring
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
It's interesting to noodle the graph...
But I'm not sure using average speed as a measurement over an entire tank works well as feedback to the driver unless the tank is predominantly highway/rural cruising, and other tanks results are over the same/similar route. (IE - controlling for as many variables as possible.)
The reasoning I decided to measure tank to tank average speed are as follows
1.My range is only 230-270 miles, circa 1 weeks driving
2.I have a basic commute of 250 miles a week- same routes at the same time of day. Therefore the majority of data was recorded on the same return journey
3.The car has a built in average sped function on the OBC
4.Variables I cant control are so large and vary so much over the course of a tank that they even out (e.g. so far this week I've had 2 dry partial commutes (one out, one back not on same day) and 4 wet ones) no to mention the temp going from 20 degrees to 9 and back to 14 in the same 3 day period.
Then there's the traffic and accidents...25 miles in 55mins today
EG: if a tank includes a siginificant mix of city/suburban plus highway motoring, how do you interpret the results & use the average speed number to your benefit?
The average speed figure represents (to me) a function of the above noted components, allowing me to guesstimate fuel costs, and review budgets. I can also check the average to see whether can afford a "spirited trip" home, or whether I have to be mega frugal
Also: does the measurement of average speed include time stopped? (EG: the ScanGauge average speed calculation is not a "rolling" average, which would be more useful. Its calculation includes time stopped.
Consider too that spread out through the year, weather effects will affect the MPG numbers (cold weather = worse mileage; warm = better). How is that separated from the average speed variable?
My ccars OBC counts it as "Key on" speed- essentially if stationary but at position II on the ignition, its calculating..
as above, I've decided that the Scottish weather its too much of a task for one man
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
